Ein neues Thema erstellen  Auf das Thema antworten  [ 4 Beiträge ]
 Betreff des Beitrags: PLUGIN_TEMP_BAN
BeitragVerfasst: 10.01.2009, 12:14
Hi!
Diese Plugin dient dazu, auch temporäre Bans nach einem Servercrash beizubehalten.
Beim Bannen muss aber nun der Befehl ausgeführt werden:
admin_tempban <playername> <bantime>
(ist bantime=0 oder leer macht es nichts!)
Um sich eine Liste der temporären Bans anzusehen:
admin_tempban_list
Weitere Hinweise:
- file_access_read and file_access_write must set to 1 in adminmod.cfg
- ACCESS_BAN is needed to execute command by admin
- IT CAN'T be used on LAN. It only stores STEAM_IDs
(maybe change line 120 and 163 the word "bBanByID" with "bBanByIP" get working it for LAN)
- Only players currently playing on server can be banned.
[SECOND EDITION]
BETA Version, must be tested!!
Änderungen:
- PLUGIN MUST BE THE FIRST PLUGIN IN PLUGINS.INI
0.95:(27.02.2009)
- added check for banned players. Only Admin with high accesslevel 131071 can overwrite temp bans. Search for "OVERWRITE_ACCESS" in sma!
- added hook for admin_ban function if time ban is used with "admin_ban"
- changed function to temp ban players by steam_id who are NOT online
- increased MAX_ENTRIES to 50
[THIRD EDITION]
admin_tempban_list displays now all currently time banned players instead of the whole list.
0.98:(28.02.2009)
- added check for correct steam_id (start with STEAM_)
- changed code for admin_temp_list
- changed code to hook for admin_ban and check for timeban.
[FOURTH EDITION (BETA)]
admin_ban_list displays also permanent bans!
1.00:(28.03.2009)
- added log data of permanent bans: command admin_ban_list
Dateikommentar: PLUGIN_TEMP_BAN4
plugin_temp_ban4.zip [11.49 KiB]
1771-mal heruntergeladen
Dateikommentar: THIRD EDITION
plugin_temp_ban3.zip [12.25 KiB]
1735-mal heruntergeladen
Dateikommentar: second Version BETA
plugin_temp_ban2.zip [11.14 KiB]
1727-mal heruntergeladen
Dateikommentar: plugin_temp_ban
plugin_temp_ban.zip [7.85 KiB]
1785-mal heruntergeladen
Zuletzt geändert von Sir Drink a lot am 30.03.2009, 20:19, insgesamt 5-mal geändert.
BeitragVerfasst: 10.01.2009, 17:39
Da hat er es doch tatsächlich wiedergefunden. :D
BeitragVerfasst: 10.01.2009, 18:11
tja... in den unendlichen Weiten meiner Festplatte... :roll:
Nur das Genie herrscht über das Chaos...
BeitragVerfasst: 30.03.2009, 20:20
4. Version, die nun eine eigene permanent bann liste führt.
Problem: da admin_unban nicht registriert ist und es auch weitere Möglichkeiten gibt, bans wieder aufzuheben, kann die Liste zur wirklichen bannliste differieren. Lösung: abgleich mit banned.cfg oder ersetzt die ban.cfg... kommt dann in der 5. Version ... Dann ist es aber komplett ähnlich meinem SDAL_BAN Plugin ;-)
